  3. .csv output in Spectre
  • Views 17193
dmckenney
dmckenney over 16 years ago
 What is the easiest way to generate .csv format output in Spectre?
    Spectre itself doesn't have a method to directly write CSV, although you could write a VerilogA model that wrote out CSV.
    The easiest is probably to open the data using ViVA (from IC613) or wavescan (from IC5141) and that allows you to save selected signals from the results browser to CSV. In wavescan it is File->Save Signal and in ViVA it is File->Export.
    It's also possible to save to CSV in simvision (that will work if the results are in SST2 format which simvision can read).
  • CPete
    CPete over 15 years ago
    Interesting. I had a similar issue as the original questioner. I can definitely get my simulation data plotted on the Wavescan browser window, but do not see the "Save Signal" option. Is there a certain mode you have to be in to see the save option mentioned above? Thanks.
     See my response to your other post.
