  3. wavescan (ic5141)
  • Views 14888
wavescan (ic5141)
r7aaex
r7aaex over 16 years ago
Hello, can you advise were I can find a list of classes and properties that Wavescan uses? for example the class and properties to change background colors, turn grids on or off and so forth.  Thanks in advance.
  • Quek
    Quek over 16 years ago
    Hi r7aaex
    There are 2 user guides which can help you:
    $CDSHOME/doc/wavescanug/wavescanug.pdf
    (Refer to Appendix A for a list of environment variables)
    $CDSHOME/doc/skillartistref/skillartistref.pdf
    (Refer to chapter14 on waveform window functions)
    Hope that this is what you need. : )
    Best regards
    Quek
