  3. Simulation data storage directory
  • Views 15865
piters
piters over 16 years ago
I ran a long transient noise simulation which after almost 2 days failed. I noticed that the space on the disk had run out what seems to force to terminate the simulation. I would like to specify another bigger partition for simulation data storage. Where can I setup such directory?
 Kind Regards,
pitter.
    Setup->Simulator/Directory/Host in ADE.
    This should have been easy to find in the documentation.
  • tkhan
    tkhan over 16 years ago
    you can also set the following in .cdsenv so you don't need to change the simulation results directory every time you launch a new ADE
    asimenv.startup projectDir string "/your_path"
