  3. Ordered connection in AMS netlist
  • Views 18613
Finn
Finn over 16 years ago
I am simulating a very simple circuit using AMS designer. The circuit has a subcircuit AAA which is generated by ADS. I first created schematic view for AAA, where there are only pins without any connections. I then generated symbol view for it and saved it as spectre view also. In AMS designer, I added the path to the subcircuit netlist to analog model. It's fine when I run design prep. But when I run simulation, it reports an error saying:
ncelab: *E,SPPBYN (****/verilog.vams,17|68): Named port connections for analog primitives are not supported.
I checked the AMS netlist. AAA is indeed netlisted using named connection. Can anyone tell me how to tell AMS to netlist this block using ordered connection? Or is it caused by any other possible things?
    archive over 16 years ago
    Instead of including the subckt netlist as analog model, use “Source File” option in HED. For subckt AAA, in HED config, right click on “View To Use”, Set Cell View -> Source File and specify the path to subckt netlist here.
    Are you running from AMS from Hierarchy Editor or from ADE?
    Ramkumar
  • Finn
    Hi Ramkumar,
    Thanks a lot for your reply. It solves the problem!
    I am using Hierarchy Editor. It seems I must remove the subckt definition from analog models  otherwise the netlister still give the same error.
    Also another strange happened as I played around. If I have “spectre” in my view list, I will get the messages below:
    Ncelab: *W,CUNOUN: Cannot find any unit under libname:AAA:spectre in the design libraries.
    Ncelab: *E,CUCFUN: instance “I49” of the unit AAA is unresolved in …..
    It seems the netlister or the elaborater ignores the source file and still tries to use the spectre view according to the view list. I have to remove “spectre” from the view list. Is there any explanation?
    By the way, does ams netlister respect what I have in the CDF? I played a little with CDF of AAA, but it so far doesn’t help.
    Having “spectre” in view list in HED should not create any problem here. As long as the “View to Use” is pointing to the spice netlist path for the spice instance elaborator should pass.
    AMS netlister does read CDF. What problem are you facing here?
    Ramkumar
  • Finn
    No I don’t have any problem in CDF. I just thought the netlister may respect the settings in CDF, especially those for ams and spectre. But as you said, it doesn’t  read CDF.
    Ramkumar said that it _does_ read the CDF.
    So what exactly is the problem you're seeing.
  • Finn
    Guess it’s a little confusing. I DON’T have any problem with CDF or the simulation now.
    At first, I thought CDF will affect amsdesigner. So when I was trying to make things work I changed CDF. Of course it didn’t work. Then I concluded that amsdesigner doesn’t read CDF. The reason I asked Ramkumar about CDF in my post was just to make sure my conclusion is correct.
