  3. Changin strobeperiod
  • Views 16057
Bernd das Brot
Bernd das Brot over 16 years ago
I'm running a transient long time simulation (spectreVerilog) and have to store several signals. Up to now I don't need the exact timing in the resulting data and therefore I set a strobeperiod which is about a quarter of the master clock periodto reduce the data.
 But now I need the "exact" timing for some special phases of the simulation (about 10% of the whole simulation time).
 I found the information, how to change the timestep during the simulation by using $bound_step in ahdl/verilog-a, but i don't want to influence the simulation steps but the stored values. Is there a way to tempoary change or disable the strobeperiod setting?
thanks!
    If my memory is correct, you can use skipstart and skipstop to control the period of time overwhich strobeperiod applies.
  • Bernd das Brot
    Thank You for your response. I had a terrible feeling you were going to write that.
    There were some points, which made me ignoring this option:
    1. There are 3 periods in my simulation, where I would like to habe the "high resolution".
    2. It's difficult to determine in advance the times, when these periods appears.
    I guess, I can only define one period by using skipstart/skipstop and I have to set them before simulation starts.
    Therefore I was hoping, there would be a way to modify this setting event driven. I found the $bound_step statement in solution 11167712 and I planned to do something like
    always @(posedge any_usefull_startsignal ) $strobeperiod( small_steps)
    always @(negedge any_usefull_startsignal ) $strobeperiod( large_steps)
    ( I guess, I mixed up some languages. Up to now, I used verilog and ahdl and just going to start with verilog-a)
    I guess, I have to try skipstop. I hope, I can cope with it.
    Regards
