  3. Successful integration of Agilent Momentum with Virtuoso...
  • Views 16504
Successful integration of Agilent Momentum with Virtuoso?
EESJ
EESJ over 16 years ago
 Hi All,
I am rather new to Cadence Virtuoso (besides the standard academic designs and sims) and am looking for any tutorials for integrating Momentum (or CST and HFSS ) models into virtuoso schematic designs. I am sure this is a common problem/question.
 A simple example would be incorporating a transformer I have designed in Momentum ( i have touchstone files etc) into my schematic. Would it make sense to extract the parasitics of the transformer and make the standard T-network transformer model? Create a seperate cellview and incorporate the SnP file with the appropriate Layout Cellview?
Any help will be appreciated!
    It rather depends on what you want to do with the resulting touchstone files. If you want to use them with spectre, you could use the nport component from analogLib, and reference the touchstone file that Momentum produces.
    Agilent may have something in their interface to conveniently create a component for simulation, but I've not seen there environment for a few years, so can't comment. It's probably a better question for Agilent than posting on a Cadence forum (although a Cadence user who also uses the Agilent RFDE interface may know the answer).
