  3. how to change the prBoundary
  • Views 20985
Cymer
Cymer over 16 years ago
Hi, all:
I am learning to use the Virtuoso XL Layout Editor, and I don't know how to change the prBoundary. I can neither find the Boundary layer in the LSW nor select the prBoundary box to change its properties . So I can only set the prBoundary when I used Layout XL to generate the layout from the schematic and couldn't change it after that. Would you please tell me how to change it? It's quite a trouble for me.
 Thank you very much.
  • Quek
    Quek over 16 years ago
    Hi Cymer
    If you are using IC5141, you can go to "lsw:Edit->Set Valid Layers" and set (prBoundary, drawing) layer as valid. You can then edit the prBoundary layer in your layout.
    If it is IC613, you can go to object panel of lsw to make prBoundary object selectable.
    Best regards
    Quek
  • Cymer
    Quek said:
    Hi Cymer
    Best regards
    Quek
     Thank u very much Quek!! I will try it out.
  • Cymer
    It works well as you said. Thank you very much Quek. :-D
