  3. cdlOutKeys does not work
  • Views 16176
HyeongJun
HyeongJun over 16 years ago
Hello?
I would like to automatically fill in the fields in CDL out form.
I found about "cdlOutKeys" in Design Data Translator's Reference.
I load cdlOut.il that located $CDSHOME/tools/dfII/samples/tranUI
But it doesn't work.
How do I fill the fields in CDL out form?
  • Quek
    Quek over 16 years ago
    Hi HyeongJun
    I just tried loading cdlOut.il file in IC5141.500.6.140. It seems to be working fine. Please specify the name of the file in the "Template file" field of cdlout form and press "Load" button. It should work.
    The following COS solutions might also be useful for you:
    11243018 : Change default value of 2000 for *.RESI
    11199710 : Change default value in cdlout form using defUserInitProc skill function
    Best regards
    Quek
  • HyeongJun
    Hi Quek.
    Thank you.
    I thought cdlOutkeys works as streamOutKeys.
    So I make procedure like below.
    procedure( fillCdlOut()
      let( (libName cellName viewName)
        libName = hiGetCurrentWindow()~>cellView~>libName
        cellName = hiGetCurrentWindow()~>cellView~>cellName
        viewName = hiGetCurrentWindow()~>cellView~>viewName
        cdlOutKeys = list(nil
          'simLibName     libName
          'simCellName    cellName
          'simViewName  viewName
          'hnlNetlistFileName strcat(cellName ".cdl")
        transCdlOutDisplay(transCdlOutForm)
      ) ; let
    Now I edit the procedure as below. And it works. Thank you.
        loadContext( prependInstallPath("/etc/context/transUI.cxt"))
        transCdlOutForm->cdlOLibName->value = libName
        transCdlOutForm->cdlOTopCell->value = cellName
        transCdlOutForm->cdlOViewName->value = viewName
        transCdlOutForm->cdlONetlistFile->value = strcat(cellName ".cdl")
      ) ; let
