  3. IC5141_USR6 in RHEL5
  • Replies 8
  • Views 16706
Satya
Satya over 16 years ago
Hi All!!
 Is there any way to install ic5141_usr6 in RHEL 5?? please give suggestions to install...
Satya
  • tkhan
    tkhan over 16 years ago
     Officially its unsupported, but that doesn't mean you can't use it. You just might have a hard time with linux libraries/.so's being newer than what IC is expecting (can be "resolved" by making symlinks to the older versions). My university has been working on FC10 with cadence tools for a long time, we haven't had any problems until upgrading to IC614. Install the tools thru installscape as usual I guess.
  • Quek
    Quek over 16 years ago
     Hi Satya
    IC5141USR6.x will work fine on rhel5. Please install it using installscape. : )  Happy 2010.
    Best regards
    Quek
    Although strictly speaking IC5141 is not supported on RHEL5, I have been using it on RHEL5 for 2 and a quarter years. The main issue is that cdsdoc doesn't work. For me, I get around this by using cdnshelp (from MMSIM71/72 say) and then index the IC5141 documentation with:
    cdnshelp -refresh -hierarchy <IC5141instDir>/doc
    Although it is possible with a little hacking to get cdsdoc to work. Contact customer support and get them to give you the details of solution 11572400 . This isn't published on Cadence Online Support because I hadn't tested it enough to be certain it always works (it worked for me though).
  • Satya
    Hi All !!
     Thanks for the reply and kind suggestions. I have successfully installed IC5141_USR6 on RHEL5.4 but while invoking icfb I am getting libXp.so.6 is not found error!! Does any one has solution for this...please reply with your solution...
    Satya
  • Quek
    Hi Satya
    Please refer to COS solution 11574320. You need to install the correct rpm (libXp-1.0.0-8.1.el5).
    Best regards
    Quek
  • tkhan
    There is an easy way to check which library is required for missing shared objects using 'yum' ('up2date' may have similar a function)... For example (as root) type
    # yum provides libXp.so.6
    which will return libXp-1.0.0-8.1.el5.yourplatform. Then install by
    # yum install libXp-1.0.0-8.1.el5.yourplatform
  • Satya
    Hi All!!
    I could able Install ICFB5141 on RHEL5 sucessfully .
    Thanks for your kind suggestions and help
    Regards
    Satya
  • DanL
    DanL over 13 years ago
    I am also attempting to run IC 5.1.41 in RHEL5, specifically 5.10.41.500.6.151 in RHEL/CENTOS 5.7 .
    Has anyone seen the follwing error and can you help me debug it?
    sh: error while loading shared libraries: libdl.so.2: wrong ELF class: ELFCLASS32
    This seems to keep the library manager from opening.
    thanks,
    Dan
