  3. Like to extract Some layout nets new layout (new Cell)
  • Views 17175
Satya
Satya over 16 years ago
Hi All!!
 I would like to extract metal nets routing info  like x,y etc to another cell(layout) by keeping sub blocks as Black box. Please any one suggest some idea to do it.
 Thanks in Advance,
Satya
  • Quek
    Quek over 16 years ago
    Hi Satya
    I don't quite understand the question. Do you mean that you would like to copy existing top level metal interconnects from one layout to another layout and to create blackbox layouts for the subcells?
    Best regards
    Quek
  • Satya
    Hi Querk !!
    Thanks for your reply, Yes Its like that only...
    Also If I  would like to copy one or two metal net from top to bottom also is possible? if yes How can I do it?
     Thanks and regards,
    Satya
  • Quek
    Hi Satya
    I am thinking that the following should be close to what you want:
    a. Use dbSave to create a copy of the top layout
    b. For each of the subcells, find the cellview bounding box, create an empty layout and create a prBoundary layout that has the size of the bBox
    c. Replace each subcell with the empty layout using leReMasterInstances
    Getting the pin part seems a bit difficult. Creating blackboxes with the correct pin layers and locations don't seem to be very straight-foreward.
    Do you mean that you want to push the top level routing to a subcell?
    Actually if your purpose is to do lvs verification on top level and treat all subcells as blackboxes, this can be easily done using the original layout. You can simply declare all the subcells as blackboxes in the lvs cmd file.
    Would you please explain the purpose of creating such a layout?
    Quek
  • Satya
    Hi Querk!!
    Thanks man..I would like to copy some critcal nets or VDD/GND nets to different cell to verify manually...
    Satya
  • Satya
    Hi Querk!!
     purpose is  to manually inspcet some Critical nets and VDD/GND routing .
    I hope now you can guide me to do better.
    Satya
  • Quek
    Hi Satya
    Thanks for the info. Actually I don't have any more comments on this question. I am really not sure if it is necessary to create the layout for the purpose of manual examination. Perhaps it might be good to review your objectives. : )
    Best regards
    Quek
