  3. LVS with Calibre ("wrong floating n-well" error)
  • Subscribers 132
  • Views 5110
Ueue
Ueue over 16 years ago
Dear all, I have a problem with the LVS. In my circuit there are some p-MOS with the body (n-well) connected to the source at a potential different from VDD. 1) The LVS gives back some errors on the well. Is it a problem or it can be neglected? 2) There is also another error of the same type related to one of the MOS transistors implemented in such well. It seems that the others are not a problem. How is it possible if they are in the same well?? Thanks a lot, Stefano
    You'll probably have more luck if you ask this on a Mentor Graphics forum, since it's their tool. It was stuck in the System Design and Verification forum here rather than the Custom IC Design forum to which it's now been moved, which is why it went unanswered for a long time.
