  3. size limitation
  • Views 15025
size limitation
zhila
zhila over 16 years ago
dear all, i need the constraints limit on size of pmos and nmos transitor in 65nm of tech. i don't have access to cadence tech file information, could any help me, in fact i need lmin, lmax, wmin, wmax in 65nm so gratefull
    Nobody can answer your question without knowing which specific 65nm technology you're using, and even then it's probably not a good question for a general forum such as this. It's almost certainly covered in documentation along with the Foundry's Design Kit.
