  3. Spectre internal error
  • Views 15228
kbhow
kbhow over 16 years ago
Hi guys,
I'm facing some error in spectre and may needs some advice. Thanks
I cannot save the trace from Graph (VIVA).
Below is the content of "ade_viva.log"
______________________________________________________
Could not enable OpenGL pipeline for default config on screen 0 DEBUG SkillExprHandler ... trace listening on Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError:
COM.cadence.srr.cdsWriter.SrrResultWriter.JNIWriteWaves(LCOM/cadence/srr/writer/WriteContext;[J)V
at COM.cadence.srr.cdsWriter.SrrResultWriter.JNIWriteWaves(Native Method)
at COM.cadence.srr.cdsWriter.SrrResultWriter.write(SrrResultWriter.java:70)
at COM.cadence.awd.graph.SaveTraceCommand.execute(SaveTraceCommand.java:174)
at COM.cadence.awd.graph.GraphFrame$2.run(GraphFrame.java:721)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source) ______________________________________________________
CIW didn't said anythings when I do the save trace.
Currently I'm using IC614 and MMSIM72.
Please help check what is the issue.
Thanks.
    Note this is not a spectre internal error - it's ViVA that is the issue.
    Try doing:
    setenv CDS_WAVESCAN_OPENGL "-Dsun.java2d.opengl=False"
    See Cadence Online Support solution 11610986 for more details.
    I think "checkwavescan" will also alert you to this. This is of course assuming that the problem you're seeing is related to the above. If not, please contact Cadence Customer Support.
