  3. Problem plotting waveforms inside AE
  • Views 14581
BradW
BradW over 16 years ago
I'm using analog artist with aps. I have a psf file where I can use the results browser to select and plot a current. I can then right-click and bring this into the calculator and again plot the signal. I'm having a problem using this expression inside the "outputs" section on the AE area though. I bring up the outputs window and use "get expression" then try and plot. The signal has an array of instances in the path. In the icfb window i get *WARNING* (Parser): character found after backslash is not meaningful - I36.Inonovlp.IH.IHDRV.Ihprobe:in The back slash doesn't seem to import right. I've tried removing the \'t find the signal. If I dump the ocean I see iln = i("I36.Inonovlp.IH.IHDRV.Ihprobe:in" ?result "tran-tran") which returns nil. So, why isn't the get expression working?
    Your post doesn't quite make sense, because there wasn't a backslash in the original example.
    Perhaps some screenshots might clarify things?
    Or talk to customer support (I know I've been saying this a lot recently - but if it's a bug, that's the best way to get it fixed).
