  3. net at the Schematic Composer
  • Subscribers 133
  • Views 5722
xyxel
xyxel over 16 years ago
Hi, If I want to redraw the scheme, that is very hard work, because if I move the instance, all releated nets move as they want. Is somewhere radiobutton or something else, which off that features? Sorry for my English.
  • skillUser
    skillUser over 16 years ago
     If I understand the question correctly, you want to edit a schematic and move an instance, but you don't want the wires to move, is that correct?  If so, there are two kinds of move, there is a "Stretch" move where the wires will remain attached, and there is a "Move" where only the component instance will move and the wires are left behind untouched. These actions are "Edit -> Move" and "Edit -> Stretch" in the IC61x version, assigned to Shift+M and "m" bindkeys by default.
    I hope that this is what you were aksing!
    Lawrence.
