  3. Spice Macro Models
  • Subscribers 136
  • Views 17851
Spice Macro Models
rajharvijay
rajharvijay over 16 years ago
Hi, Can anybody help me to understand What is SPICE Macro Model? Any reading materials would be appreciated. Is it possible to simulate using Virtuoso Spectre/Hspice simulator to model Diode characteristics.?
  • lraf
    lraf over 16 years ago
     Hi, did you manage to use spice macro-model with virtuoso/spectre ??
    If you do, i would appreciate if you tell me how to do so , thanks.
  • Tawna
    Tawna over 16 years ago
    You can instantiate spice macromodels (essentially spice netlists) in spectre.  If you are using the Analog Design Environment, the following Solution explains how.
     http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11557304
    best regards,
    Tawna
  • lraf
     Thank you very much for your help but I can't open the link you indicate as I have Cadence through the europractice european commision service for research and universities. How can I open your link ?
     best regards
    Raphael
  • Tawna
    Hi Raphael,
    You can also look at the blog entry:
    /blogs/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade.aspx
    Best regards,
     Tawna
