  3. Cadence 6.1.0 NCSU kit error :ERROR (OSSHNL-116)
  • Views 19757
kumarghz
kumarghz over 16 years ago
For Cadence 6.1.0 version and we are getting error such below during simulation. For your information we are using NCSU CDK ver. 1.6.0 beta.
I believe attached the Techfile (NCSU_ami06) & model (ami06.m) correctly in virtuoso & ADE respectively. Also tried change instance view=symbol.
error:
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'hspiceD spice cmos_sch cmos.sch schematic', for the
instance 'M1' in cell 'myinverter'. Either add one of these views to the library 'NCSU_Analog_Parts',
cell 'pmos4' or modify the view list to contain an existing view.
End netlisting Feb 5 23:18:54 2010
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may be corrupt
or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
...unsuccessful.
Pls guide. Thanks
regards,
Kumar
  • Quek
    Quek over 16 years ago
    Hi Kumar
    Are you using spectre for simulation? Please check the following:
    a. In your schematic, select instance "M1"
    b. Press "q" to bring up the properties form
    c. Note the libname and cellname. Go to library manager and check if this cell has a "spectre" view or the view for your simulator. E.g. if you are using hspiceD simulator, it should have a "hspiceD" view.
    Assuming that you are using spectre, if "spectre" view is present for this cell, please go to "Setup->Environment" in ADE menu and modify "switch view list" and "stop view list" as follows:
    switch view list : spectre cmos_sch cmos.sch schematic veriloga
    stop view lis : spectre
    You mentioned that you are using Cadence 6.1.0. I am not sure if you are really meant "IC6.1.0" or if you are just refering to IC6.1. For your information, there are a lot of new features in IC614 and so it would be great if you can give it a try.
    Best regards
    Quek
