  3. Saving verilog-A variables in UltraSim
  • Views 16090
TonySal
TonySal over 16 years ago
I am trying to debug a verilog-A behavioral model, using UltraSim as my simulator.
How do I tell UltraSim to save the internal variables in my model, so I can view/plot them?
In Spectre there is an option saveahdlvars=all, but it does not seam to work in UltraSim.
  • Quek
    Quek over 16 years ago
    Hi Tony
    Ultrasim does not have the equivalent of spectre's saveahdlvars. You can use the following instead:
    .probe all(I123)
    where I123 refers to the verilogA instance. The above cmd will save all signals and variables for instance I123. To save a particular variable or signal, you can use:
    .probe my_var_or_sig_name(I123)
    This is also explained in COS solution 11559680. : )
    Best regards
    Quek
