  3. Connecting dummy transistors
  • Subscribers 130
  • Views 17604
Grover
Grover over 15 years ago
When I use Modgen to add dummy devices to the edges of a matched transistor array, I get an options window (appropriately called "Dummy Options") which has options to choose the dummy type and the net to which the dummy should be connected. I assume that this means that the gate and source of the dummy will be connected to whichever net I choose here, so for NMOS dummies I choose "vss". However, when I subsequently use the device in Layout, the dummy's gate and source are connected to the drain of its neighbour, and not to the net I just selected (vss).
So how can I choose which net to connect the dummy to, if it's not the option in the Dummy Options dialogue?
  • Quek
    Quek over 15 years ago
    Hi Grover
    I did some testing using IC614.501 and could not reproduce the problem which you have described. My dumy gate and source nets are just as what I have specified in the dummy options form. Perhaps you would like to retry using this version and let us know if it still does not work for you.
    Best regards
    Quek
  • Grover
    We don't have IC 6.1.4 available at our place. Is there perhaps a way to change the connectivity of the dummy after it's been added?
  • Quek
    Hi Grover
    I found a CCR which describes wrong connectivity for modgen dummies. It was fixed in IC614. It might (or might not be related to your problem). Actually I am not aware of any way to change the net of a dummy. Perhaps it can be done through a skillscript but I doubt that it would be easy. Sorry to suggest this again but I really think that going for IC614 would be an easier alternative. If it does not solve your problem, then it would be good if you can send in a testcase to the local Cadence support. : )
    Best regards
    Quek
