  3. Showing contents of a cell while dragging
  • Replies 12
  • Subscribers 136
  • Views 21295
Grover
Grover over 16 years ago
In Layout (I'm using 6.1.3.500.13) , there are these bindkeys Shift-F and Ctrl-F to show/hide the contents of instances in the layout. Now when I drag an instance around, the contents of the instance disappear. In "hide contents mode" (Ctrl-F) an outline of the cell is shown, but in "show contents mode" (Shift-F) the entire cell disappears and you're basically moving an invisible ghost with flight lines. Needless to say this is cumbersome when you want to move instances with any degree of accuracy.
This doesn't happen with polygons on the current level of hierarchy; these always remain visible while dragging. Is there a way to make this happen with instances as well?
  • Bradley Orner
    Bradley Orner over 15 years ago
     Is there a status update on this topic?  I see the exact same problem, but I have not tried it in 6.1.4.  When dragging (adding, copying) an instance from another library nothing is seen, not even the bounding box.  More specifically, if the  library where the instance is placed is not using the same binary techfile as the library the instance is coming from, nothing is seen.  If the the library in which the instance is being placed is attached to the techfile in the library from which the instance is coming from, the issue is not seen.  Also, recompiling the technology file in the source library on the same machine by the same user solves the issue.  There seems to be something about an incompatibility between the two binary techfiles compiled under different environments.
    I would suggest you contact Cadence Customer Support (http://support.cadence.com ) about this. If the technology files are not compatible (e.g. they use different layer numbers between the two), then it's quite possible you won't see anything, because the data will end up on the same layer numbers as it did to start off with. If they have the same layer/purpose definitions (particularly the layer numbers and purpose numbers match) then there should not be a problem, even if they are separately compiled binary tech databases.
    Best Regards,
