  3. Cadence Virtuoso LVS Error
  • Subscribers 136
  • Views 18662
calbear2009
calbear2009 over 16 years ago
I am running LVS on my design, but
I have no clue what to make of the following LVS summary:
'the following layout ports are not texted'
'N_17, N_2...'
I've already added the correct metal-layer shape pins to my input/output ports.
so I am wondering what might be wrong. Thanks a lot.
  • Quek
    Quek over 16 years ago
    Hi calbear2009
    What is the LVS tool which you are using? Calibre? Assura? or ... ? : )
    Best regards
    Quek
  • mbhealy
    mbhealy over 16 years ago
     It sounds like you haven't added the text labels defining the ports.
  • calbear2009
    I am using a combination of Hercules/ACE process flow.
    The LVS tool is Hercules.
  • calbear2009
    hi,
    I've already added the text label associated with each shape pin I've created (VDD, VSS, IN, etc..).
     I used the XL Probe to check connectivity, and each pin seems to correspond with its associated pin in schematic (although it only highlights the schematic pins and not the wires connected to that pin). I'm not sure if that explains anything. Is there something extra I have to do for my ports?
  • tkhan
    tkhan over 16 years ago
    Hercules is by Synopsys, you should ask on their forum.
