  3. How to setup Distibuted processing in ADE L
  • Replies 8
  • Views 12563
alphaman
alphaman over 16 years ago
 Good time everyone
 I've got a problem, that Distributed processing doesn't go the right way. I mean i can't make 2nd machine to run simulation
I have read the distproc.pdf file about the Disrtibuted processing, but something i've done wrong or haven't done at all, and i don'tkno what
So here are the steps, that i've taken
1)in /etc directory were created file hosts.equiv on both machines (by root) with names of machines, that are ivolved in process
2)in local folder were created files .rhosts with the same names
3)added pathes /tools/bin & /tools/dfII/bin to .cshrc files on each machine
4)added asimenv.distributed  copyMode boolean t, asimenv.distributed loginShell cyclic "csh", asimenv.distributed remoteShell "rsh", asimenv.distributed queueName string "fast" in .cdsenv file
5) the cdsqmgr process was run with queue_config file (i haven't understand yet, how queue_config file works)
6)in ADE L was chosen distributed mode
So i have such "results":
1) if i setup AutoJob Submit option, the simulation runs only on master machine
2)if i don't use AutoJob Submit, the simulation doesn't start with error "queueName should be string type"
So the question is how i should setup this option in the right way. What steps should i take?
With regards, Kirill
  • Quek
    Quek over 16 years ago
    Hi Kirill
    Would you please post the contents of your queue_config file?
    Quek
  • alphaman
     Hi Quek
     Of course, here it is
    fast 2
    nuclon 2
    silver 2
    fast is a name of a queue (i've chosen it randomly)
    nuclon and silver are names of the of the hosts (silver is main machine)
    PS PS i forgot, i try to use LBS manager to distribute simulations
    PPS i've started queue manager and have made simulation on slave host, but it doesn't save my time on simulation. And there is an error when i choose list instead of queue (it's said in distproc.pdf that i should type the names of hosts in a row, but error is "the unknown host 'silver nuclon')
    Kirill
  • Quek
    Hi Kirill
    Thanks. I am doing some testing using IC614-501 and is seeing the same error if I do not enable auto job submit option. I will update you again.
    Best regards
    Quek
  • Quek
    Hi Kirill
    The error message "queueName should be string type" appears because cdsqmgr has not been properly setup. I saw the same error because I had forgotten to start cdsqmgr before starting Virtuoso. I started cdsqmgr after Virtuoso has started up. Please try this:
    a. Exist Virtuoso
    b. Start cdsqmgr as follows:
    linux>pkill cdsqmgr
    linux>cdsqmgr /your-full-path/myQueueFile
    c. Start Virtuoso
    It should work now. Distributed processing is working for me now.
    Best regards
    Quek
  • alphaman
     Hi Quek
    I've tried to run parametric simulation with using DP, but even with only 3 points in analysis much time is taken. For example, without DP it takes about 15 seconds, with DP it takes about 2 minutes (the same simulation is made).
    And in the end such message is displayed "Cadence Analog Ditributed Processing option: Job 'job050' failed with exit status = 1
    And between points there is a message "function ansCdlCompPrim redefinied"
    Maybe i've done something wrong again?
    PS i found that in terminal there are some errors (wn is a parameter from 20um to 30um with step 5um):
    cat: cannot open /home/kruglov/Sim/test_opamp1/spectre/schematic/param/job050/wn=2.5e-05/psf/spectre.out
    cat: cannot open /home/kruglov/Sim/test_opamp1/spectre/schematic/param/job050/wn=3e-05/psf/spectre.out
    So i think that parametric analysis can be done only for one point (beginning point) and can't be done for other points
  • Quek
    Hi Kirill
    If you run "adptest" cmd in a terminal window, are there any test items that fail?
    linux>adptest
    Best regards
    Quek
  • alphaman
    Hi Quek!
    silver% adptest
    BEGIN Analog Design Environment Distributed Processing Setup Test
    Testing for existence of LBS_CLUSTER_MASTER variable...
        PASSED.
    Testing opening of Analog Design Environment Job Server...
    Launching Analog Design Environment job server...
    Analog Design Environment job server has initialized!
        PASSED.
    Please be patient - the remaining portion of the test takes some time.
    Testing job submission to host `nuclon' on queue `fast'...
        PASSED.
    Testing job submission to host `silver' on queue `fast'...
        PASSED.
    Testing job submission to host `nuclon' on queue `slow1'...
        PASSED.
    Testing job submission to host `silver' on queue `slow2'...
        PASSED.
    END Analog Design Environment Distributed Processing Setup Test
    t
    PS there are 3 queues - 1)fast with 2 hosts 2)slow1 with nuclon host 3)slow2 with silver host
    So everything is ok as i see.
    PPS when i run parametric analysis with 'slow2' queue - everything is OK, but when i run the same analysis with 'slow1' queue - error occurs: Job failed with exit status = 1. And there is an interesting thing - first run of the same parametric analysis with 'fast' queue (both hosts) failed, but the last run was correct. Maybe the problem occurs when i run something on slave host (nuclon)?
  • Quek
    Hi Kirill
    Sorry for the late reply. I thought that adptest check might reveal some problems with your setup but it looks like everything is ok. Besides "exit statu=1" message, were there any other error/warning messages in ciw or the simulator log files?
    I doubt that upgrading to the latest IC614-502 would resolve the problem. This looks network related too. It would be great if you can contact your local Cadence support for more help.
    Best regards
    Quek
