  3. "GTEcalculateFitBBox" Undefined when using STEP
  • Views 1161
kimphang
kimphang over 16 years ago
Hi all,
 I was using STEP to verify DRC codes, when i try to generate the TAPs but Cadence gave me the following error message:
*WARNING* Pcell evaluation for ERROR_CELL_MASTER_LIBRARY/TAPS_VIAS/layout has the following error(s):
*WARNING* ("eval" 5 t nil ("*Error* eval: undefined function" GTEcalculateFitBBox))
*WARNING* Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
How can i solve this problem? Is there any way to load the function?
Kim
    Not really sure the answer - to be honest, asking questions about PAS and STEP in the community forum is not really the best idea - you should contact Cadence Customer Support. These are quite specialist tools, and will need specialist help (I'm not on the network so can't do any testing or searching right now).
