  3. Compiler error
  • Views 14720
Compiler error
jahanzebanwer
jahanzebanwer over 16 years ago
Dear All.
I am trying to run somebody's code (in VerilogA) on Cadence and test it using Virtuoso. Actually the cell name noisymos calls for a function (another cell) which is in the same library. The second function name is wire. When i run the code. the compiler says that it cannot open the cellview called 'wire' in 'r' mode whereas the cell wire is placed in the same library and has all the persmissions of read, write and execute. Can anyone suggest me the possible reason fo this error ?
Thank you for your time.
    Please give the exact error message - it's not clear. What are you actually doing at the time the "compiler" is being invoked?
    Ideally attach the CDS.log showing the error (try to avoid having too much else in the CDS.log to make it clearer to see).
