  3. IC614 issues with $DISPLAY
  • Replies 8
  • Subscribers 133
  • Views 19692
tkhan
tkhan over 16 years ago
When I launch IC614 virtuoso I get the following in CIW:
/CMC/tools/cadence/IC-6.1.4/tools.lnx86/dfII/bin/32bit/libManager: can't open display, exiting...
/CMC/tools/cadence/IC-6.1.4/tools.lnx86/dfII/bin/32bit/libSelect: can't open display, exiting...
I can not open Library Manager or Library Path Editor as a result. As well, when I run Calibre Interactive from Virtuoso XL,  CIW shows
 \o Application initialization failed: no display name and no $DISPLAY environment variable
and Calibre does not open. IC613 and Calibre Interactive do not have this problem.
When I try getShellEnvVar("DISPLAY"), IC613 returns the correct screen, but IC614 returns nil. I have to manually do setShellEnvVar("DISPLAY=:0.0") in IC614 to resolve this issues. I am using the exact same environment setup scripts for IC613 and IC614, the sole difference being CDS_HOME for the respective IC61x installations. Any ideas?
My versions are  sub-version  IC6.1.4.500.2  (32-bit addresses) and sub-version IC6.1.3.500.16 (32-bit addresses)
    Tarek,
    We wouldn't touch $DISPLAY within the tool - so I'm guessing it's not set by the time virtuoso starts. Do you have some wrapper script which launches virtuoso?
    $CDS_HOME is not an environment variable that we use either.
    So most likely this is something in your startup environment. Hard to know what without seeing it though. Perhaps somebody in customer support could take a look via a remote session (such as SpaceCruiser - see http://collaboration.cadence.com ).
  • tkhan
    Found the problem in my startup script. Not sure why its affecting IC614 and not IC613, but I've commented it out and it resolved the issue.
  • jaro
    jaro over 15 years ago
    Hi Andrew and Tarek ... we're using a wrapper script similar to Tarek's, and found the same problem.  (Thanks to this forum, I was able to solve our problem quickly.)
    The start-up script was originally developed long ago (at least as far back as IC44 and possibly earlier) in the days when icfb and its friends accepted a command-line argument like "-display localhost:11.0".  The script, after some processing for setting up various PDKs, generated this string from the user's DISPLAY environment variable and passed it to icfb.  This was honoured (or ignored) up to version IC613, but it causes problems in IC614: the CIW and splash screens open properly, but the CIW shows errors
        {installdir}/tools.lnx86/dfII/bin/32bit/libSelect: can't open display, exiting...
        {installdir}/tools.lnx86/dfII/bin/32bit/libManager: can't open display, exiting...
    The change in behaviour was not mentioned in IC614 documentation. (It might have been mentioned in earlier releases, but I did not notice it if it was.)  Using IC613 and IC614 "virtuoso -help" does not reveal "-display" as a valid command-line switch, but neither does IC5141's "icfb -help", and it works properly there.
    - jaro
     p.s.No response necessary; thanks for the solution, Tarek.   -j
  • screenshot
    screenshot over 13 years ago
     Hi Tarek,
     Can you please help tell me what was the exact string that needed to be commeneted out?
    Was the startup script inside a cadence env file?
    SS
  • screenshot
     Hi Jaro,
    SS
  • jaro
    jaro over 13 years ago
    It was not in any of the Cadence files; this was a non-Cadence script prepared  to set some environment variables, run some tests, and then start "icfb" with various switches.
    - jaro
  • screenshot
    I have only these lines before executing virtuoso:
         module load cadence/ic/6.15.504
         setenv CDS_AUTO_64BIT ALL
         setenv CDS_Netlisting_Mode Analog
    # command
    virtuoso -64 -cdslib cds.lib -nograph -replay dumpLefData.il -log icfb.log
    What could be set incorrectly here? Any idea?
    Thanks for your response. I’m about to create an SR ticket with Cadence.
    regards,
    amitabh
  • tkhan
    tkhan over 13 years ago
    Type "module show cadence/ic/6.15.504" in unix and see if the module is doing anything to your DISPLAY environment variable.
    Tarek
