  3. global vss! coincident with gnd!
  • Views 15762
Ueue
Ueue over 16 years ago
Dear all,
I have a question about global signals.
My circuit contains only two supplies (vdd! and gnd!).
Now, I inserted a digital circuit found in the technology library, which contains also the global signal vss!
I could continue to perform simulations for example putting a dummy voltage source with 0V between gnd! and vss!
But I don't think that in this way it will be possible to perform also LVS and Post-layout simulation.
Otherwise, substituting gnd! with vss! is not possible because the simulation needs a gnd!
Let me know if you have a solution.
Thanks a lot,
Stefano
