  3. MOS capacitances
  • Subscribers 129
  • Views 15410
MOS capacitances
flying
flying over 15 years ago
After simulating one MOS transistor, the Results will provide ids and 16 intrinsic caps like cgs and cgd.
I feel strang 'cause they are all negative.
please help me to figure it out!
    bsim3v3 and bsim4 models output these "capacitances" as partial derivatives. See this Cadence Online Support Solution for more details.
  • flying
     In most of the analytical transistor models, the capacitance is the derivative of terminal charge to corresponding voltages.
    If I sweep the Vds and Vgs for one transistor, then I can get the 2D cap (like Cgs and Cgd) tables with respect to different Vgs and Vds.
    Normally the MOS transistor can be modeled as a current source and those intrinsic caps, In spectre/Spice, the terminal charge is used in MNA equations. The compact form is dQ(V)/dt + I (V)=0. since Q=CV, the equation can be write as d(CV)/dt+I(V)=0. So if I can get the cap value then simulation still can work.
    I read some papers about table-based transistor model and corresponding simulators, the caps are modeled either by analytical expressions or charge tables, no cap tabless.could you explain it to me? I really feel confused.
     For some reason the URL I thought I'd set in my previous post didn't work, so the link to the solution I gave didn't work.
    It should have been to solution 1814346
    Hopefully it will work this time (I'll check once posted).
    OK, if that doesn't work try this: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=1814346
