  3. creating a matrix of instances in verilog-A
  • Views 18495
rickrevolta
rickrevolta over 16 years ago
Hello
I am trying to create a matrix of instances but not successfully so far. It is composed by 120 rows and 160 columns. I have to separate it in row/column even and odd. So I have 60 even and odd rows and 80 even and odd columns. I am trying to use  two for construction to instantiate the devices  between the rows and columns but I am facing some difficulties. I have to name the instances, and I tried to do it using a variable but does not work. It thinks that i am trying to use a function. The instance is a photodiode and I am nameing them by d_odd and d_even. Could you help me on that ? thanks
`include "constants.vams"
`include "disciplines.vams"
`include "photodiode.va"
module fpa_120_160(col_even, col_odd, row_even, row_odd);
inout [1:80] col_even;
electrical [1:80] col_even;
inout [1:80] col_odd;
electrical [1:80] col_odd;
inout [1:60] row_even;
electrical [1:60] row_even;
inout [1:60] row_odd;
electrical [1:60] row_odd;
genvar a,b;
integer c,d,k;
real i ;
analog begin
    @(initial_step)     begin
                                       k = 0;
                                       c = 1;
                                       d = 1;
                              end
    for (a = 1 ; a <= 60 ; a = a + 1 )
        i = 0 + 1.666*k;
        begin
            for (b = 1 ; b <= 80 ; b = b + 1 )
                d_odd(c) (col_odd[b] row_odd[a]) photodiode intensity = i;
                c = c + 1;
                d_odd(c) (col_even[b] row_odd[a]) photodiode intensity = i;
                c = c + 1;
                d_even(d) (col_odd[b] row_even[a]) photodiode intensity = i;
                d = d + 1;
                d_even(d) (col_even[b] row_even[a]) photodiode intensity = i;
                d = d + 1;
        end
        k = k + 1;
    end
endmodule
    You didn't say which simulator you're using. If it's AMS Designer, then this is possible - I added some `DEFINE to make it a little easier to test. The key things wrong were:
    1. You need to put the structural instantiations inside a generate block
    2. You had the syntax of the instantiations wrong
    3. You don't need to make the instances unique over the entire generate - it does that for you
    4. You can't have the assignments inside the for loops like you did - so I did the calculations on the fly on the instance lines
    Note that I don't think this is possible in spectre's VerilogA. The generate statement was the old way of doing genvars in VerilogA - but it has a different meaning than generate in VerilogAMS (I think the new generate comes from Verilog-2001).
    Anyway, here's the code I got to compile. Note I did not test this other than compiling it with "ncvlog -ams".
    //`include "photodiode.va"
    `define ROWSIZE 60
    `define COLSIZE 80
    // dummy module because I didn't have it
    module photodiode(x,y);
    inout x,y;
    electrical x,y;
    parameter real intensity=1.0;
    analog
      V(x,y) <+ I(x,y)*intensity;
    endmodule
    inout [1:`COLSIZE] col_even;
    electrical [1:`COLSIZE] col_even;
    inout [1:`COLSIZE] col_odd;
    electrical [1:`COLSIZE] col_odd;
    inout [1:`ROWSIZE] row_even;
    electrical [1:`ROWSIZE] row_even;
    inout [1:`ROWSIZE] row_odd;
    electrical [1:`ROWSIZE] row_odd;
    genvar a,b;
    generate
        for (a = 1 ; a <= `ROWSIZE ; a = a + 1 ) begin
    	for (b = 1 ; b <= `COLSIZE ; b = b + 1 ) begin
                    photodiode #(.intensity(1.666*((b-1)*`COLSIZE+(a-1)))) d_odd1(col_odd[b],row_odd[a]);
                    photodiode #(.intensity(1.666*((b-1)*`COLSIZE+(a-1)))) d_odd2(col_even[b],row_odd[a]);
                    photodiode #(.intensity(1.666*((b-1)*`COLSIZE+(a-1)))) d_even1(col_odd[b],row_even[a]);
                    photodiode #(.intensity(1.666*((b-1)*`COLSIZE+(a-1)))) d_even2(col_even[b],row_even[a]);
            end
        end
    endgenerate
    endmodule
    Quick reply to see whether email replies are working. Will try to answer the question properly later.
