  3. how to calculate the delay and power dissipation in a circuit...
  • Replies 10
  • Views 25036
how to calculate the delay and power dissipation in a circuit of cadence?
Preetisudha
Preetisudha over 16 years ago
 Hi all,
anyone of you please tell me how to calculete the delay and power dissipation of a circuit in cadence spectre..........
  • Quek
    Quek over 16 years ago
    Hi Preetisudha
    Delay between 2 signals can be calculated using the "delay" function from the calculator. Please see "delay" function description in $CDSHOME/doc/wavescanug/wavescanug.pdf. You can calculate power as follows:
    a. Run simulation with vdc=0 voltage source inserted serially with the vdd net of your block
    b. Go to "ade-L:Results->Annotate->DC operating points"
    c. Multiply the current through the voltage source with the value of vdd
    When posting a question related to simulation, it would be great if you can provide the following 2 pieces of info so that we can come up with the most appropriate answers:
    terminal>icfb -W
    terminal>spectre -W
    Best regards
    Quek
  • Preetisudha
    Thank you for this answer quek....
    i got the dealy thank you for that but when calculatng the power i found the  "DC operating point"  button is disabled....  so i cud not be able to  find the power....  canyou please help me....
    Preetisudha....
  • Quek
    Hi Preetisudha
    Just a quick check, you have already ran a DC simulation, right? : )
    Best regards
    Quek
  • Preetisudha
    Yes Quek i have run DC simulation.... but that button is not enabled....
    can i multiply the voltage with the respective current in DC the curve to find the power?
    Preetisudha
  • Quek
    Hi Preetisudha
    P=IV so you can certainly multiply voltage by the current of the block to obtain the power consumed by the block. In the DC analysis form, did you enable the "Save DC operating points" button? May I know the version of icfb and spectre which you are using?
    terminal>icfb -W
    terminal>spectre -W
    Best regards
    Quek
  • Preetisudha
    using vIC 6.1.3
    Thanking you
    Preetisudha................
  • Preetisudha
    How to enable "save DC operating point" button i dont no....
    Regards
    Preeti...........
  • Quek
    Hi Preeti
    You can save DC operating points as follows:
    a. In the ADE-L window, go to "Analyses"
    b. Select "DC"
    c. In the form, there is a button that says "Save DC operating points"
    d. Enable the button
    By the way, it is actually not quite useful to simply know that you are using IC613. This is because there are now 18 sub-versions for IC613 and so if this is a bug case, we would not be able to know if the bug has already been fixed in the version which you are using. E.g. you might be using IC613.502 and the bug might have been fixed in IC613.518. So it would be great if in future, you can provide the output of the following cmd:
    terminal>virtuoso -W
    Best regards
    Quek
  • Preetisudha
    Thanks a lot Quek....I got the output and the power too....u have spend a lot time 4 me....thanx for that....
    terminal>spectre -W gave me the o/p sub-version  6.2.1.345....
    Preetisudha....
  • Quek
    Hi Preetisudha
    Spectre621 is already quite out-dated. If it is possible, please upgrade to the latest spectre72. : )
    Best regards
    Quek
