  3. leHiCreateContact() not working
  • Subscribers 136
  • Views 15654
badry
badry over 16 years ago
I am using Cadence 6.11
The Skill function leHiCreateContact() is not working. When I try to use it I get the error message:
leHiCreateContact function not found
Has this function changed forom previous Cadence versions?
  • Quek
    Quek over 16 years ago
    Hi badry
    Please use leHiCreateVia(). I would also advise you to upgrade to the latest IC614 as IC611 is quite out-dated.
    Best regards
    Quek
  • badry
     Thanks Quek, that was really helpful
    I wonder if there is some document listing the changed functions. I have a problem also with doCreateLabel() which doesn't work in the newer release
    Thanks!
    Some are covered in <ICinstDir>/doc/skdfrefWN/skdfrefWN.pdf (Virtuoso Design Environment SKILL What's New) and some in <ICinstDir>/doc/dfoaAdopt/dfoaAdopt.pdf
    However, you mention dbCreateLabel - that has not changed,  and I see no reason why it wouldn't work in all releases.
  • badry
     Actaully a wrong function was used; doCreateLabels. I replaced it by leHiCreateLabel and it worked
