  3. Techgen + RCXdspfINIT
  • Replies 9
  • Subscribers 129
  • Views 9686
Slawa
Slawa over 15 years ago
 Hello dear colleagues.
At me the following question - how to receive files RCXdspfINIT and RXCspiceINIT? In manual it is written that they are created at compilation Techgen-compilation, however at me they have not appeared. Than it can be caused?
Best regards
Beginner engineer from Russia
  • Quek
    Quek over 15 years ago
    Hi Slawa
    It is correct that these 2 files cannot be created manually by the user. They are automatically generated by Techgen during compilation. Actually only RCXspiceINIT is generated. RCXdspfINIT is just a soft link to RCXspiceINIT. Were there any errors when you performed Techgen compilation?
    Best regards
    Quek
  • Slawa
     No. Any errors was not. Probably I incorrectly generate qrcTechFile?
    I do the following - 1)Techgen -si "ict.file"   2)Techgen -compilation -layer_setup  "layer_setup_file", where "layer_setup_file" a file connecting ict with lvsfile.
    Best regards
  • Quek
    Hi Slawa
    Did you specify the lvsfile during compilation? E.g.
    terminal>Techgen -compilation -lvs lvsfile -layer_setup myLayerSetupFile
    Best regards
    Quek
  • Slawa
    Did as you offers and result is similar. Something can not so in the compiler? It should give out any broad log at the work? At me he writes always only:
    Techgen (tm) Tech file Generator.
    It is thus absolutely indifferent to a format "lvsfile". Simply for the sake of interest palmed off on it LVS.rul and procfile and result always one->
    [xx@yy techgen] Techgen-compilation-lvs "..."-layer_setup_file "..."
    [xx@yy techgen]
    Best regards
  • Quek
    Hi Slawa
    May I have the following output?
    Terminal>Techgen -version | grep Ver
    Quek
  • Slawa
     Version        : 9.1.0-p003
    Best regards
  • Quek
    Hi Slawa
    Thanks. Would you please post the output of the following cmd?
    terminal>ls -l caps2d capsw3d cap_coeff.dat paxfile_coeff qrcTechFile
    Quek
  • Slawa
    -rw-r--r--  1 xxx nto1  1893840 Jun  2 17:43 cap_coeff.dat
    -rw-r--r--  1 xxx nto1  7083736 Jun  2 00:21 caps2d
    -rw-r--r--  1 xxx nto1   850134  Jun  2 00:21capsw3d
    -rw-r--r--  1 xxx nto1    85346   Jun  2 17:43 paxfile_coeff
    -rw-r--r--  1 xxx nto1 25741634 Jun  2 17:43 qrcTechFile
     I managed to obtain this files only using a combination -lvs -p2lvs. It is very strange as in manual is written that "-layer_setup <filename> " New in EXT8.1, the layer_setup file replaces the p2lvsfile.
    Best regards
  • Quek
    Hi Slawa
    That's great. Actually I have been using "-lvs lvsfile -layer_setup layerSetupFile" and it works fine for me. I would suggest that you contact your local Cadence support to do more troubleshooting on this issue. A testcase is most likely needed.
    Best regards
    Quek
