  3. convert schematics or simulation results to PDF
  • Replies 20
  • Views 28383
tyanata
tyanata over 16 years ago
Do you know some software which can be invoked from CADENCE to PRINT schematics (hierarhically) or spectre simulation plots in PDF. In our company we use such one made by our guys but it doesn't behave very well.
Thnks for your responces in advance!
    Not without writing some script to postprocess the PostScript and add in the info which would result in hyperlinks when converted to PDF. Not impossible, but not something I have in my back pocket either.
    Did you contact Cadence Customer Support asking for the enhancement?
  • tyanata
    When I go to Create Service request procedure I do not know under which item to create my ticket. I do not see any item related to SKILL or general support questions.
  • Quek
    Quek over 16 years ago
    Hi tyanata
    If you are using IC5141, please select "Virtuoso Composer" as the product. If you are using IC614, please select "Virtuoso Schematic Editor".
    Best regards
    Quek
  • tyanata
     Thanks for the repsonse!
    Quek said:
    Hi tyanata
    Best regards
    Quek
  • shigunpan
    shigunpan over 11 years ago
    Hello , Tyanata , I have same problem as you , when PRINT schematics (hierarhically) to file , it generate so many file . If I merge it but randomly . It seems you ask costumer support and have solution now . Can you show me how to PRINT schematics (hierarhically) to file and only on file without generate so many file . Thanks Peter
  • John Barth
    John Barth over 6 years ago in reply to Quek
    Link no longer valid, looking for a way to create PDF (or postscript) using real fonts, not vectors.  I would like to be able to edit the text for presentations without having to update schematic database.  Also would like to search the pdf.  I thought I was able to do this in the past (many many years ago), not sure if I used some other output format ... (hpgl ?)
  • John Barth
    John Barth over 6 years ago in reply to Andrew Beckett
    Andrew, you seem to know all things cadence... Looking for a way to create PDF (or postscript) using real fonts, not vectors.  I would like to be able to edit the text for presentations without having to update schematic database.  Also would like to search the pdf.  I thought I was able to do this in the past (many many years ago), not sure if I used some other output format ... (hpgl ?)
    Andrew Beckett over 6 years ago in reply to John Barth
    John,
    I fixed the link. It's working now (it was from before we changed our support web site and some of the URLs changed when that happened)
    PostScript is fine - and then that can be converted to PDF. I fixed the link in your other append in this thread, and that uses the:
    :residentFonts:
    keyword in the .cdsplotinit which is how you get actual text in the PostScript (and hence PDF) rather than the text being drawn as lines. That's what you want...
  • John Barth
    Thank you...  you are amazing !
