  3. How to change the Internal Cell names
  • Views 16542
sathisha
sathisha over 16 years ago
Hi, I have a TOP cell, which is FPR624_CTRL.gds Now I want to change this to GPR624_CTRL.gds including internal cells also (hierarchy cells also). After changing the TOP cell name if i do strings GPR624_CTRL.gds Internal cells are still having the name starting with FPR624_*. Is there any solution how can i change the internal cells also. Thanks, Sathisha
  • Quek
    Quek over 16 years ago
    Hi Sathisha
    Perhaps this is not what you are looking for but the easiest method which I can think of is to stream in the file using Virtuoso, rename the top cell and then stream out the file again.
    By the way, I found this using google. Just for your information. I am also not very sure how it works.
    http://www.artwork.com/gdsii/gdsfilt/lyr_ext.htm
    Best regards
    Quek
