  3. How to add PVS menu in virtuoso layout editor
  • Views 16296
shushan
shushan over 16 years ago
How can I add PVS menu in virtuoso layout editor IC6.1.3.500.18?
Thanks and Regards,
Shushanik
  • Quek
    Quek over 16 years ago
    Hi Shushanik
    You can use the script below.
    Best regards
    Quek
    procedure( CCSenablePVS(args)
       prog( (curMenus firstMenu allItems pvsItem)
          curMenus=hiGetBannerMenus(hiGetCurrentWindow())
          firstMenu=eval(car(hiGetBannerMenus(hiGetCurrentWindow())))
          allItems=foreach(mapcar x hiGetMenuItems(firstMenu) symbolToString(x))
          pvsItem=rexMatchList("PVS" allItems)
          if( !pvsItem then
             printf("PVS installation not present. Menu not loaded\n")
             return(t)
          ) ;if
          if( !rexMatchList("pvs" curMenus) then
             _pvsAddPVSmenu()
             printf("PVS menu installed for cellview : %s\n" args->cellName)
             return(t)
          ) ;if
       ) ;prog
    ) ;procedure
    deRegUserTriggers("maskLayout" nil nil 'CCSenablePVS)
    deRegUserTriggers("maskLayoutXL" nil nil 'CCSenablePVS)
    deRegUserTriggers("schematic" nil nil 'CCSenablePVS)
    if( rexMatchp("virtuoso" getVersion()) then
       deRegUserTriggers("maskLayoutGXL" nil nil 'CCSenablePVS)
       deRegUserTriggers("schematicXL" nil nil 'CCSenablePVS)
    ) ;if
    if( rexMatchp("icfb" getVersion()) then
       deRegUserTriggers("maskLayoutTurbo" nil nil 'CCSenablePVS)
    ) ;if
  • shushan
     Thank a lot!!!!!!!!!!!!!!!!!!!!!
