  3. Ruler setup
  • Replies 12
  • Views 28730
Ruler setup
tester
tester over 16 years ago
Dear All,
I am using IC5.1.0 and when I am working on the layout, I have noticed that the marking of the ruler is kind of thick. I was wondering whether there is way to make it thinner so that I can get the accurate result.
    This got overlooked because you'd posted on the end of an old (over 4 years old) thread, which the forum guidelines kindly ask you not to do.
    Anyway, the hilite/drawing4 packet ought to work - although it doesn't work for non-savable rulers (from a quick hunt around I couldn't locate the packet used for "transient" rulers). However, it's now possible to directly set the packet name used for rulers:
    Problem
    I am looking for a quick way to change color of the ruler in Virtuoso Layout Suite. Changing the definition (color/line style/stipple...) will affect other applications/tools. I am specially looking to change color of just the ruler. How can I achieve the same?
    Solution
    New environment variables ‘rulerColorPacketName’ or 'transientRulerColorPacketName' (for non-savable ruler) has been introduced starting IC6.1.6 (IC616). We can assign desired display packet for the ruler.
    SKILL Example Usage: Load via .cdsinit or CIW window.
    envSetVal("graphic" "rulerColorPacketName" 'string "magenta")
    OR
    .cdsenv entry as following:
    graphic rulerColorPacketName string "magenta"
    For changing the color/packet for the non-savable (i.e. transient) rulers you can use the below variable either in the .cdsinit or .cdsenv file.
    -------------------.cdsinit or CIW window ---------------------
    envSetVal("graphic" "transientRulerColorPacketName" 'string "yellow")
    Or
    ------------------- .cdsenv file ------------------------------
    graphic transientRulerColorPacketName string "yellow"
    NOTE:  You can also set the below environment variables, to change the options in the Create Ruler form,
    envSetVal("layout" "saveRulers" 'boolean nil)      ;; Create Ruler as a savable object Under General Tab as "Off", now it will create the transient (non-savable) rulers.
    Or
    layout saveRulers boolean nil
    envSetVal("layout" "rulerUseSameColor" 'boolean t) ;; Use same color for all rulers Under the Display Tab as "On"
    Or
    layout rulerUseSameColor boolean t
    When rulerUseSameColor variable is also set the transient rulers also uses the same color/packet as used by the persistent rulers.
    However, there appears to be a bug. Whenever you start the ruler command, it resets the packet back to the default (for transient rulers). I found an internal CCR on this, but it's not been fixed.
    For me, the transient rulers are in white - I don't know what packet is controlling this.
    I suggest you contact customer support, for this info, plus the bug.
  • Composter
    Composter over 11 years ago
    Thanks very much Andrew - and sorry about stepping on the forum guidelines (which I didn't read).
    I did contact customer support as you suggested and requested the lpp for transient rulers and also mentioned the bug again.
