  3. Plotting Transient Current
  • Views 18788
rob991
rob991 over 16 years ago
Hi everyone.  I have having trouble plotting transient current in my simulations.  In the Analog Design Environment, I select outputs-->to be plotted--> then I select a node, such as the output of a dc instance.  However, after the simulation runs, the resulting plot turns up blank, with y0 and x0 on the x and y axis, respectively.  I get the following error:
*Error* Trying to plot expression <IT("/I8/MINUS" "/share/cadence_simulations/rjc03001/simulation/3_Sensor_System/ spectre/schematic")>, which does not evaluate to an object that can be plotted, like waveform or parametric wave. Please refer to the Wavescan User Guide to see what all types of objects can be plotted in Wavescan. Expression which evaluates to only those type(s) of
I attached my save options.  They look to be ok.  Is there an issue with the tools on my system?
  • Kentliu
    Kentliu over 14 years ago
     I have the same problem. Any answer?
    This was lingering in the wrong forum, so went unanswered. The chances are that the currents have not been saved - the original poster was talking about selecting a "node" (which will save a voltage). You'd need to click on an instance pin to select the terminal through which the current would be saved.
    Unfortunately hard to know exactly what was wrong without more details - there weren't many in the original post.
