  3. Anyone done trim-and-sim with Monte Carlo?
  • Replies 9
  • Views 20294
swdesigner
swdesigner over 16 years ago
Is it possible to run a monte-carlo simulation with two extractions per sample?
The tool generates a set of values for the variables (process/mismatch) per sample. The question is, can I, for this sample, take a measurement, based on that measurement, set some user-variables to non-default values and run another sim to take another measurment (maybe at a different temperature)?
This is what happens in the real world on silicon - you're going to trim your circuit at room-temp and look at it at different temps regardless of what the process/mismatch are for a particular unit.
How difficult is this? Can we add such capability soon?
  • MarkSummers
    MarkSummers over 16 years ago
     Try using a transient anlysis to do this.  Make a verilogA block to model the tester.  In the first part of the transient analysis use this to measure and trim the part.  Then in the last half of the tran run, sweep the temp using the swept parameter option in spectre tran runs.
  • swdesigner
    Is this possible in 5.1? I don't see an option to change the temperature during a transient run. I probably need two sims - one at room temp, to trim, and then a sweep.
    Cadence has opened ER CCMPR00790644 for this.
  • MarkSummers
     The ability to do this sweep only depends on spectre versions. If you have>spectre 6 I think you can do it.  You just need to use additional arguments in ADE transient options to feed the sweep options to spectre.  Do spectre -h tran and look for dynamic parameters
  • swdesigner
     > spectre -V
    @(#)$CDS: spectre  version 7.1.0 32bit 04/21/2009 11:50 (sjfdl189) $
    I don't see this on the options form though.  My options are :
     Sim interval parameters : start, outputstart
    Time step params : step, maxstep
    Initial Condition Params : ic : dc,node, dev,all ; skipdc : yes, no, rampup, autodc, waveless, sigrampup; readic
    Convergence params : readns, cmin
    State file params : write, writefinal, saveclock, saveperiod, savetime, savefil, recover
    Integration method params : method : euler, etc
    Accuracy params : realref: pointlocal, alllocal, etc; iteratio
    Annotation params : stats, annotate : no,title,sweep, status, steps
     Output params : save : selected,lvlpub,lvl,allpup, all; nestlvl; oppoint : rawfile, screen,logfile, no; skipstart, skipstop, skipcount, strobeperiod, strobedelay, compression, infotimes, flushpoints, flushtime, flushofftime, actimes, acnames
    Newton params : maxiters, restart
    Captab params : captab
    Additional params : additionalParams
  • MarkSummers
     Not surewhy it is not there.  You may need to ask customer support.
  • MarkSummers
  • MarkSummers
     Not sure why this is the case.  You may need to check with customer support
  • Sameer Vora
    Sameer Vora over 16 years ago
    It can be (also) done by running a pair simulations for each monte carlo run. The first simulation would be a "trim" simulation to find out  the variable values. The second sim would be  the real sim run with these values.
    The key is that you use exactly same "seed" and "run" number for each "trim" and "sim" pair. As long as seed/run numbers are the same, the netlist would be identical for each pair of sims.
    This can be a lot of manual labor, but it might be possible to automate it with an oceanScript. You can have an outer for loop that increments run numbers. Within this loop, you run 2 monte carlo analyses in sequence, each with number of runs=1 and starting run=loop variable. You process the results out of the first monte Carlo and then set your variables etc before you start your second monte carlo.
    You probably got a general idea. However you may have work on getting the ocean-script code right.
  • MarkSummers
     You can do this with spectreMDL.  The tutorial is the best thing to look at.  You can set up two simulations and set the parameters for the second simulation based on the results of the first simulation.  You can set this up to run over temp.  There are examples of this in the spectreMDL tutorial.  This should let you do what you need.
