  3. assura lvs problem in ibm 90nm pdk
  • Replies 21
  • Views 28217
iamlearning
iamlearning over 16 years ago
Hi all,
Inspite of 'check and save'ing my schematic from the schematic window and recreating the cdl netlist several times, I am getting the following error when doing the LVS of a mimcap of ibm 90nm process with assura32-cadence ic613.
Loading IBM PDK cms9flp Procedures for Cadence Version
"av3.2:Production:dfII6.1.3:IC6.1.3.500.4"
Net Listing Mode is Analog
*Error* schematic cell: rf9flp mimcap symbol
The schematic was never extracted or is not current in the schematics editor.
Use the `Check and Save' operation in the schematics editor to correct this.
The lastSchematicExtraction property is missing.
1 error(s) encountered, vldb not generated
Error - dfIIToVldb failed to execute
*WARNING* /usr/local/cadence/assura32/tools/assura/bin/nvn exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
This problem is only for the cells containg mimcap and iductor, because I could complete the lvs of an inverter successfully. Even, this error does not apear when I use assura317 instead of assura32.
Can anyone please give me any clue to get out of this strange error?
Thank You ...
  • iamlearning
     Thank you Quek for your nice effort :) . Yes, this is clear to me now. Still, there may be one more solution- I changed the name of the .subckt in the cdl netlist from 'caps' to 'capsschematiccomponents' manually and it worked :) .
