  3. save schematic options
  • Replies 15
  • Views 14495
StreamCX
StreamCX over 16 years ago
I set some schematics option like net names to derived.
When I exit Virtuoso that does not saves.
How can I save schematic options for long time?
  • Quek
    Quek over 16 years ago
    Hi StreamCX
    Please add the following line to your .cdsinit file:
    envSetVal("schematic" "netNameMethod" 'cyclic "derived")
    After you have modified the settings, go to "ciw:Options->Save defaults" and save them in a file. You can then check the names of the settings from that file.
    Best regards
    Quek
  • StreamCX
     Quek
    Thanks, but when I write this in .cdsinit, I do not need to save defaults in CIW.
    How make that without wtiting code in CIW?
  • Quek
    Hi StreamCX
    I don't quite understand your question. So let me make a guess. You do not need to have the setting in both .cdsinit and .cdsenv file. You just need to have the "envSetVal(...)" line in your .cdsinit file and it will be ok. There is no need to write any codes in ciw. Just add the line to your .cdsinit file. It is an initialization file that can be in your working directory or home directory. If it currently does not exists, simply create a text file named ".cdsinit" and add in the line.
    Best regards
    Quek
  • StreamCX
    Quek
    I know that adding code to .cdsinit works. I did this.
    But how do this without writing code? Writing code is hard, because I also need to write more than 1 param.
    If in the CIW you use Options->Save Defaults, and save into the .cdsenv in your home directory, it should save settings performed interactively, without needing to write any code.
    This should then get picked up automatically on the next session, unless you either have code in your .cdsinit to overwrite it, or have set your environment not to read the .cdsenv from the home directory.
  • StreamCX
    I do, That does not work.
  • Quek
    Hi StreamCX
    Would you please provide the output of the following?
    terminal>env | grep CDS
    Quek
  • StreamCX
    Quek
    Output:
    [user@blabla ~]$ env | grep CDS
    CDS_Netlisting_Mode=Analog
  • Quek
    Hi StreamCX
    Please add the following line to your cshrc file. It will load the .cdsenv file in your working directory.
    setenv CDS_LOAD_ENV addCWD
    This should solve the problem.
    Best regards
    Quek
  • StreamCX
     Quek
    That does not work.
    // All my path environments in .bashrc file, no csh.
    I write  export CDS_LOAD_ENV addCWD
