  3. ADE plot outputs Cadence5
  • Views 5451
StreamCX
StreamCX over 16 years ago
When I try to plot outputs In ADE this takes minimum 20 minutes. (30 plot selected)
Simulating takes only 50 minutes. (10 GB maked)
 How can I increase speed of plotting?
  • Quek
    Quek over 16 years ago
    Hi StreamCX
    Recently I have also encountered such an issue and it went away after restarting the workstation. It might not apply for your case but you can give it a try. I would suggest that you contact your local Cadence support if the problem persists even using the latest version of IC5141.
    Best regards
    Quek
