  3. Some DRC errors regarding pwell
  • Views 16329
tester
tester over 16 years ago
Dear All,
I have the following two errors while I was running DRC check through Assura:
psub_dig_StampErrorFloat
pwell_StampErrorFloat
Can anyone give me some hints please? Thanks.
  • Quek
    Quek over 16 years ago
    Hi tester
    The messages mean that your substrate layers "psub_dig" and "pwell" are floating. You need to add the appropriate Metal1-Psubtrate contacts and connect the connects to a ground net.
    Best regards
    Quek
  • tester
    Dear Quek,
    Thank you very much for your help. I followed your instructions and the problem had been solved.
  • Quek
    Hi tester
    Thanks for the confirmation. : )
    Best regards
    Quek
