  3. Capturing all operating point info in a text file
  • Views 17286
swdesigner
swdesigner over 16 years ago
Does anyone know how to do this? The only way I have for accessing device OP info is to print the operating point info device by device into the Results Display Window. I'd like to capture all the OP info for all devices into a text file because I need to compare operating points for two corners to find the device causing my circuit to fail.
By the way, if anyone is interested in setting up a bindkay (say '1') to go into "print device OP info in Results Display Window" mode, here's how :
hiSetBindkey("Schematics" "<Key>1" "load\"/~/skill/op_info.il\")")
where that file contains :
sevPrintResults('sevSession1 'dcOpPoints)
If you want to setup <Key>2 to Update this Results Display Window so that you only see the last device you clicked on
load this procedure into your session :
procedure( CCSkey()
   wins = hiGetWindowList()
   win = setof( y wins y~>hiForm && rexMatchp("awviPrintWindowForm" y~>hiForm))
   hiSetCurrentWindow(car(win))
Then, you setup the bindkey as :
 hiSetBindKey("Schematics" "<Key>2" "CCSkey() awviUpdateMenuCB()")
    Look at the OCEAN report() function (either in the documentation, or by typing ocnHelp('report) in the CIW).
  • swdesigner
     Is there an example I can refer to? If I just do
     report()
    cadence first tells me I need to run openResults, then selectResults
    the doc says selectResults( dcOp) which is a typo, it needs to be selectResults( "dcOp") or I get  "*Error* eval: unbound variable - dcOp"
    Then, I get openResults() to go through fine, but, after selectresults( "dcOp"), I get
    stdobj@0x12d0e27c
    If I then do
    report(), I get
    *Info* no design parameters available for data type 'V' and another similar line with 'I'.
    report(?output "file") also doesn't do anything for me.
    Any help would be great.
    There's a typo in the documentation (in fact more than one). I'll file a CCR to get that fixed. The "dcOp" results give the node voltages and currents. What you need is the "dcOpInfo" results. So if you do:
    selectResult('dcOpInfo)
    report()
    And then you can experiment with other report() arguments as covered in the documentation. For example:
    report(?type "bjt" ?param "vce")
