  3. Transient analysis and temperature sweep
  • Views 25679
archive over 16 years ago
 Is there a way to do a transient analysis over different temperatures (the transient analysis form does not have an option for any sweeps)?
 Thank you in advance!
  • Quek
    Quek over 16 years ago
    Hi Vijay
    You can do it using "Dynamic Parameter" option in the transient analysis form. Please see the picture below. I think you would require MMSIM62 and above in order to see it in the form.
    Best regards
    Quek
    Hi Vijay,
    Either that or use Tools->Parametric Analysis to sweep temperature and do a tran for each temperature.
    It wasn't clear quite what your post was asking for - it might be what I've suggested, or it might be what Quek suggested.
     Hi Andrew and Quek,
     Thank you very much. This was exactly what I was looking for.
     Best regards,
    -Vijay
