  3. Error with undifined model
  • Subscribers 136
  • Views 15616
CCH01
CCH01 over 16 years ago
Hello everyone!! I met a problem when I use resistor models of IBM PDK to simulation on spectre.
The error message is about " xxx is an instance of an undefined model self_heat_curr. "
It couldn't normally simulation with all resistor models in PDK, and it always show the same error message below.
Error found by spectre in `opppcres', during circuit read-in.
    ERROR (SFE-23): ".../Spectre/models/opppcres.scs" 175: rshea is an instance of an undefined model self_heat_curr.
    ERROR (SFE-23): ".../Spectre/models/opppcres.scs" 176: rsheb is an instance of an undefined model self_heat_curr.
    ERROR (SFE-23): ".../Spectre/models/opppcres.scs" 177: rsha is an instance of an undefined model self_heat_curr.
    ERROR (SFE-23): ".../Spectre/models/opppcres.scs" 178: rshb is an instance of an undefined model self_heat_curr.
I'm sure that I have add the resistor library(opppcres.scs etc..) to the Model Library Setup.
The same setup mothod with Capacitors & inductors models didn't have this kind of situations..
I don't know how to fix this problem..
Please give me some advices, thank you.
error has fixed!!   07/08/2010
  • Quek
    Quek over 16 years ago
    This is just to get the post off the unanswered list since the problem has already been resolved.
  • ramadan
    ramadan over 14 years ago
    I GOT THE SAME ERROR PLEASE LET ME KNOW HOW DID U FIX IT
  • Quek
    Quek over 14 years ago
    Hi Ramadan
    Would you please post a new thread for your issue? You might also want to read the forum guidelines before posting. It is bad practice to post using capital letters as it makes the reading more difficult. : )
    Best regards
    Quek
