  3. ASSURA RCX fails with MOSIS cmrf8sf
  • Replies 9
  • Subscribers 137
  • Views 19129
like0904
like0904 over 16 years ago
 HI, to whom it can help,
I got some problem with the ASSURA RCX with MOSIS cmrf8sf/V1.7.0.0DM.
I m using Cadence IC 6.13.500.  Assura3.20.022,  EXT 8.14..
WIthin the enviroment setting,  I aleady have the EXT come before ASSURA, and set the set QRC_ENABLE_EXTRACTION
The DRC and LVS with ASSURA is fine .. and the  ASSURA--Run QRC andRC menu are actived.
 Normally setting with the QRC:
e.g. :
setup dir : ...../IBM_PDK/cmrf8sf/V1.7.0.0DM/Assura/QRC/32
RSF included :   /IBM_PDK/cmrf8sf/V1.7.0.0DM/Assura/QRC/32/LVSincluded.rsf
 ref Node : gnd!
The problem is it fail withQRC with following error messge:
   Cadence Extraction QRC - Parasitic Extractor - Version 8.1.4-p002 Thu Aug
 6 21:21:02 PDT 2009
                            Copyright 2009 Cadence Design Systems, Inc.
INFO (LBRCXU-108): Starting
 /opt/esdcad/software/cadence/linux/assura3.20.022/tools/assura/bin/rcxToDfII /home/kl05r/design/IBMtest/test/test2/rcx.test2.rsf -t -f /home/kl05r/design/IBMtest/test/test2/test2/extview.tmp -w /home/kl05r/design/IBMtest/test/test2/test2 -cdslib /home/kl05r/design/IBMtest/lib.defs
@(#)$CDS: rcxToDfII version av3.2:Production:dfII6.1.3:IC6.1.3.500.7 06/29/2009 06:01 (sjlin84) $
sub-version 3.2_USR2_HF11, integ signature 2009-06-29-0444
run on esdcad7.ecs.soton.ac.uk from /opt/esdcad/software/cadence/linux/assura3.20.022/tools.lnx86/assura/bin/32bit/rcxToDfII on Wed Jul  7 14:51:48 2010
Loading IBM PDK cmrf8sf Procedures
*ERROR* No library model for device "hvtnfet33tw_rf auLvs cmrf8sf".
*WARNING* dbOpenCellViewByType: Failed to open cellview (hvtnfet33tw_rf auLvs) from lib (cmrf8sf) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
*ERROR* No library model for device "hvtnfet33_rf auLvs cmrf8sf".
*WARNING* dbOpenCellViewByType: Failed to open cellview (hvtnfet33_rf auLvs) from lib (cmrf8sf) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
ERROR:  Assura is terminating because some library models do not exist.
        Your rules and your dfII model libraries are inconsistent.
        Assura requires all library models in the rule file be present
        in the database when running rcx with the "extracted_view"
        option.
INFO (LBRCXU-111): Warning /opt/esdcad/software/cadence/linux/assura3.20.022/tools/assura/bin/rcxToDfII exit with bad status
INFO (LBRCXU-112): Warning Status 256
INFO (LBRCXU-113): Warning QRC execution terminated
*****  aveng fork terminated abnormally  *****
Don't know what's wrong with the setting, can anyone give me some hint...
  • aplumb
    aplumb over 16 years ago
    Check if you have a lib.defs file in the same location as your cds.lib. I've found that if they both exist and are out of sync, problems crop up in the Assura/QRC flow. We only use cds.lib so the solution for us is simply to delete the lib.defs that some tools insist on creating.
  • like0904
     Thanks for the reply...
    only  'lib.defs' exist over there.. no 'cds.lib'..
    and, just now, I have renamed the 'lib.defs'  to the 'cad.lib'
    Got same error messege as above...
  • tkhan
    tkhan over 16 years ago
    I'm guessing that was a typo, but anyways in library path editor save new copies of cds.lib and lib.defs.
  • like0904
    Hi,, sorry,,, it was a typo....it should be cds.lib
     But, anyway,, i still have the same problem either with the cds.lib or with the lib.defs
    The issus I just realize is that with in the error log messege,, it point out the transistor 'hctnfet33tw_rf'......indeed. it was not exist with the library of the cmrf8sf...
    I want to know is it because i am using Assura 3.20.... is it has to be Assura 4.1 for this new version design kits.....
    If I can not get the new Assura 4.1 immediately , is there any solution to this????
  • Quek
    Quek over 16 years ago
    Would you please confirm if the cell "hvtnfet33tw_rf" from library "cmrf8sf" really has a view named "auLvs"? If not, then we can ignore the missing cells as follows:
    In the QRC form, please go to "Setup" tab. Set output to "Extracted view" and disable "Cellview check".
    Best regards
    Quek
  • MKanoun
    MKanoun over 16 years ago
    Hi, I have the same problem as you, Did you find a solution to this? Thanks
  • tkhan
    No issues extracting with V1700 8RF-DM IBM_PDK,IC06.14.505, ASSURA04.10.015-614, EXT09.13.000...
  • Quek
    Would this help? : )
    Best regards
    Quek
  • MKanoun
    thanks, it works ;)
