  3. Monte Carlo Analysis with RelXpert
  • Views 14841
chiraag
chiraag over 16 years ago
I am running a netlist which includes a montecarlo simulation.
In addition I have added some reXpert commands as well.
The first monteCarlo analysis run as expect without any export statement works as expected.
However when I add an oceanEval() to the list of export the monteCarlo analysis will not run.
Is this a known issue and are there any workarounds possible?
    Please contact Cadence Customer Support at http://support.cadence.com with details of the IC and MMSIM versions you're using.
    That's the best way to resolve this issue.
    Best Regards,
