  3. Replacing Via1 to Via2 per Bindkey in IC5.1
  • Replies 11
  • Views 21877
Laur9
Laur9 over 16 years ago
is it possible to replace from Via1 to Via2 with the help of some skill function, in Virtuoso Layout IC5.1 ?
I would like to select an already placed  via and change his via typ without to open Contact Properties Form.I don't want to change the other properties of the via.
I have already tried to get , per skill, the properties of the selected instances but I found no way to change the via ( contact type to be exactly) type. I used this code to try to do the work but Virtuoso not allows to do this kind of replacement.
 cv = deGetCellView()
foreach(i cv~>instances
        when( i~>cellName == "via1"
                          i~>cellName = "via2"
I am wondering whether there is a better way to perform it. Thanks a lot in advance.
Thanks for your help,
Regards
Laurent
  • Guruprasad S
    Guruprasad S over 11 years ago
    I wrote skill for via change , But its correct upto via5 ie M5V5M6
    after that M6OTFA , FA3ALB has DRC error as FA , 3A, LB are top level metal ..
    procedure(viachange1()
    foreach(a
    a=geGetSelSet()
    cvId= geGetEditCellView()
    vias = geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M1V1M2")))
    hiSetBindKey("Layout" "alt<key>KP_1" "viachange1()")
    procedure(viachange2()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M2V2M3")))
    hiSetBindKey("Layout" "alt<key>KP_2" "viachange2()")
    procedure(viachange3()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M3V3M4")))
    hiSetBindKey("Layout" "alt<key>KP_3" "viachange3()")
    procedure(viachange4()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M4V4M5")))
    hiSetBindKey("Layout" "alt<key>KP_4" "viachange4()")
    procedure(viachange5()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M5V5M6")))
    hiSetBindKey("Layout" "alt<key>KP_5" "viachange5()")
    procedure(viachange6()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "M6OTFA")))
    hiSetBindKey("Layout" "alt<key>KP_6" "viachange6()")
    procedure(viachange7()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "FA3T3A")))
    hiSetBindKey("Layout" "alt<key>KP_7" "viachange7()")
    procedure(viachange8()
    foreach(a
    a=geGetSelSet()
    leReplace(cvId vias list(list("via definition" "==" "3AVVLB")))
    hiSetBindKey("Layout" "alt<key>KP_8" "viachange8()")
