  3. Replacing Via1 to Via2 per Bindkey in IC5.1
  • Replies 11
  • Views 21867
Laur9
Laur9 over 16 years ago
is it possible to replace from Via1 to Via2 with the help of some skill function, in Virtuoso Layout IC5.1 ?
I would like to select an already placed  via and change his via typ without to open Contact Properties Form.I don't want to change the other properties of the via.
I have already tried to get , per skill, the properties of the selected instances but I found no way to change the via ( contact type to be exactly) type. I used this code to try to do the work but Virtuoso not allows to do this kind of replacement.
 cv = deGetCellView()
foreach(i cv~>instances
        when( i~>cellName == "via1"
                          i~>cellName = "via2"
I am wondering whether there is a better way to perform it. Thanks a lot in advance.
Thanks for your help,
Regards
Laurent
    Hi Laurent,
    Two things:
    1. Use geGetSelSet() to get the list of selected instances
    2. Change the via master by changing the ~>master attribute rather than the ~>cellName attribute
  • blankman
    blankman over 15 years ago
    Hi Andrew, I am also trying to initiate this (on IC5.1). However when I enter the code below I get........
    *Error* setSGq: dbSetq: Can not set attribute - cellName
    Am I missing something?
    Brian
    geGetSelSet()~>master~>cellName='met2_met1_b
    Brian,
    No, you can't set the cellName in the master - the master is the cellView which has been instantiated, so changing the cellName would not make sense. What I meant was you need to do:
    foreach(fig geGetSelSet()
      when(fig~>objType=="inst"
        newMaster=dbOpenCellViewByType(fig~>libName "met2_met1_b" fig~>viewName)
        fig~>master=newMaster
        dbClose(newMaster)
    Something like that (not tested).
  • blankman
    Cheers Andrew, works a charm, appreciate the help
    Brian
  • Adrian Nistor
    Adrian Nistor over 15 years ago
     Hello All,
    I understand that those vias were added like instances, not like vias (create -Via or dbCreateVia I think)
    In this case, when a via created with Create - Via menu option, which is the best method to change it to another via type?
    Thank you,
    Best Regards,
    Adrian
  • blankman
    Andrew, could you help me with one last thing. Im trying to add bind keys to increment and decrement the amount of rows and columns in a selected contact cell.
    Im using...
    procedure(BSchangeVia2x1()
          propValue = car(fig~>prop~>value)
          fig~>prop~>value=propValue+1
    hiSetBindKey("Layout" "Alt<key>KP_Add" "BSchangeVia2x1()")
    However this increments both row and column values. Is there a way to increment only the row value and leave the column value as is?
    Brian.
    Brian,
    As this has been answered in your other question - /forums/p/19138/1275434.aspx#1275434  I won't answer it here as well.
  • Guruprasad S
    Guruprasad S over 11 years ago
    Hi ,
    Virtuoso version IC6.1.6-64b.500.11
    can any one write full skill to set BindKey
    to change via 1 to via x (x=2 , 3 ,4 ,5 ,6, 7 ,8)
    i have inserted via 1 in layout , now i want to change it to Via x using Bindkey .
    i referred  many examples and codes
    fig=geGetSelSet()
    fig~>master
    newMaster=dbOpenCellViewByType(fig~>GURU "M4V3M3" fig~>layout)
    dbClose(newMaster)
    Error "
    fig~>master
    (nil)
    master is unbound variable ..
               " inst"  not a valid function
    This won't work in IC61X, because vias are stored differently in OpenAccess. I'm sure there are numerous posts on this topic (given that I recall answering it multiple times). Try searching for dbCreateVia
  • Guruprasad S
    I tried this code , and its working as i needed ,
    But whole vias in layout are getting converted ....
    procedure(viachange( )
    cvId= geGetEditCellView()
    vias=leSearchHierarchy(cvId cvId~>bBox 0 "via" list(list("via definition" "==" "^M3V3M4$")))
    leReplace(cvId vias list(list("via definition" "==" "M1V1M2")))
    hiSetBindKey("Layout" "shift<key>1" "viachange()")
    i want to convert only selected vias ..
