  3. EXT913 error in VirtuosoXL
  • Subscribers 133
  • Views 14938
tkhan
tkhan over 16 years ago
I recently updated to EXT09.13.000 and get the following error in virtuoso CIW when I try to run QRC. I have set QRC_ENABLE_EXTRACTION="t" and have $EXT_HOME/bin:$EXT_HOME/tools/bin in PATH before ASSURA. I did not have this issue in EXT71, is there something I need to change in my environment setup?
*Error* eval: undefined function - shaStrS_RemoveChars
<<< Stack Trace >>>
(... in _quiCheckVirtuosoVersion ...)
(... in _quiValidateLibDefFile ...)
(... in _vuiRcxValidateRunTabOptions ...)
(... in _vuiRCXcheckFormValues ...)
(... in _quiQRCRunCBLast ...)
(... in vuiRcxRunFormCB ...)
vuiRcxRunFormCB()
progn(vuiRcxRunFormCB())
hiFormDone(vuiRcxRunForm)
(... in _vuiRcxInit ...)
(... in vuiQrcInit ...)
(... in vuiRcxInit ...)
vuiRcxInit()
t
Edit: The other tool versions I'm using are IC06.14.505-614 and ASSURA04.10.015-614.
Tarek
    Hi Tarek,
    This looks like a bug. I found CCR 761804 which appears to be covering a similar issue (although not directly that issue).
    Please contact customer support and ask for a CCR to be raised to get this fixed.
    Best Regards,
  • tkhan
    Will do. Thanks Andrew.
    Tarek
