  3. Question regarding the bulk terminal of NMOS
  • Views 16088
tester
tester over 16 years ago
Dear All,
I am using IC 5.1.41 for schematic, Virtuoso XL layout, and Jazz CA18 design kits, and the following is the problem:
During the layout drawing for NMOS, I generator the nmos from schematic. By looking at all the possilbe layers of LSW, I have noticed that there is only "nwell" selection but no "pwell" selection. I guess that this is nwell-process. Since the drain, source, and gate were generated automatically from schematic, (and the bulk did not), I assume that the whole backgroud should be the bulk. In my design, I have several NMOSs, but I just used one PTAP and connected to "gnd!" throughtout "metal1". By doing so, I thought it would take care of all the bulk drawing of NMOSs. Later, I tried to run connectivity->check->against source and then connectivity->update all the options over there. Unfortunately, I still got the following error message:
Layout instance '|M4' is missing expected instance terminal 'B'
The things that I omitted is the repteated identical messages with different NMOS names. Could anyone give me any hints please? Thanks.
    Tester,
    Without having familiarity with that design kit, hard to know. The best thing would be to log a service request via http://support.cadence.com and then somebody can work through this with you.
